enable tacacs
enable tacacs
Description
Enables TACACS+ authentication.
Syntax Description
Default
Disabled.
Usage Guidelines
After they have been enabled, all web and Telnet logins are sent to one of the two TACACS+ servers for login name authentication.
The following command enables TACACS+ user authentication:
enable tacacs
Platform Availability
